Underpower Shrike 40
Reply
Old 03-21-2006, 09:36 AM
Blue Ribbon
My Feedback: (133)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Underpower Shrike 40
I got an excellent buy on a 80% completed Shrike .40 kit, not ARF. Look at putting an OS .46AX in it, but it is going to be a very very tight squeeze.
My flying skills are "medium" - I an NOT looking for terror white knuckle speed. I'm looking for a fun aircraft. (I am NOT going to use gear. I have no problem with combat planes, though they may have more lift than the Shrike.)
I know you speed deamons are going to kill me, but what if I put something like a GWS .32 in the plane. I did a lot of searching, and everything I found is on going faster and fast verticle. I'm looking sport plane.
If I go to a OS .40, it is the exact same size as the .46 AX, so I haven't gained anything. I've also looked at the GWS .40 and Super Tigre .40, but I'm not saving anything on size or weight.
Would appreciate feed-back.
Bill
Blue Ribbon is offline
Old 03-21-2006, 09:47 AM
ksubigbuck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Underpower Shrike 40
go for it if you want. With that motor it should still have enough power to sport fly. However, this plane is built to go FAST! While a smaller engine will slow it down a little, it will still be somewhat fast, and will probably land fast. Should be a great plane for sharpening you reflexes. hehehe
ksubigbuck is offline
Old 03-21-2006, 08:07 PM
redfox435cat
redfox435cat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is the perfect plane to learn how to deal with speed. Get the 46 and fly it. The first couple weekends just fly around 1/4 to 1/3 throttle. It'll be like the .32 at 3/4 throttle. then try some 1/2 to 2/3 throttle straight line bursts, do that for a couple weekends. Then go full throttle a few time before you know it you'll be flying it around full throttle from launch to empty tank and do just as comfortably as your trainer. at that point put a 9x8 prop for more speed. Before you know you'll start looking to put a Rossi or Jett on it. dealing with fast models is just a frame of mind. if you think you can't then you can't, ease into it and your mind will catch up
redfox435cat is offline
