Any body know what this plane is worth???
Reply
Old 03-24-2006, 06:44 AM
Midget
 Midget's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Any body know what this plane is worth???
Hello.
not sure if this is the right places to post this....but here it go's
Ive being offed this plane, but I'm not really sure how much it is worth
I'm not sure what type of engine is in it. so if you guys know any think about these
planes and how much there worth i would really appreciate it.
Thanks heps
http://www.users.bigpond.net.au/i_am...ahl/plane1.jpg
http://www.users.bigpond.net.au/i_am...ahl/plane2.jpg
http://www.users.bigpond.net.au/i_am...ahl/plane3.jpg
http://www.users.bigpond.net.au/i_am...ahl/plane4.jpg
http://www.users.bigpond.net.au/i_am...ahl/plane5.jpg
http://www.users.bigpond.net.au/i_am...ahl/plane6.jpg
 Midget is offline
Old 03-24-2006, 08:14 AM
britbrat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Any body know what this plane is worth???
It was dug out of a tomb, or sand dune, right?
IF the engine runs well, & IF the radio works well, & IF the servos all work, & IF the battery is OK, it could be worth ~ $200 Cdn, but looking at the condition, I'd say $100 - $125 max, & much less if any of the major bits are duds.
But that's Canada -- things is different in Oz
britbrat is offline
Old 03-24-2006, 11:22 AM
Campy
Campy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How much is the person going to pay you to take it ?
As Agent Midget said, there are A LOT OF IFS with the plane.
Also consider that you can buy a brand new trainer, 4 chanel radio and 46 ball bearing engine for about $300 (US ). Over here, a used trainer setup in good conditon with everything working goes for about $175 - $200.
Some of the "ifs" you need to consider: If the transmitter battery needs to be replaced you are looking at $30, $20 for the receiver battery, $10 for a servo, $3 for fuel lines, $5 for a fuel tank (which probably will need replacing, along with the fuel lines based on appearances ). The other if is what repairs need to be done? I can see some damage (it APPEARS minor ), but until you get in there you can't tell how extensive it is. Do you have the necessary skills (and equipment ) to do the repairs ?
The prices are approximate - they may be higher or lower depending on where you get them.
Hope this helps.
Campy is offline
Old 03-24-2006, 11:51 AM
FLYBOY
FLYBOY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As stated, if the engine turns over and the plane is ok, $100 would be ok, but the radio is probably not good. Batteries for it cost as much as a new one in most cases. The thing doesn't look to be in great shape. If you do buy it, change the instalation of the radio. Those clips on the servos with the screw that goes down to hold the wire in place is really bad. It will cause the plane to crash when the screw comes lose and you have no control. That tells me that a newbie built it, so I would look close at it and question how the rest it put together.
FLYBOY is offline
Old 03-24-2006, 11:57 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since you already have a thread with the same title, I'm going to close this one.
Please, only one thread per question.
MinnFlyer is offline
