flaperons for F4U
NC
flaperons for F4U
Just building an F4U and had to put one servo for each aileron and I have them connected with a Y harness. Do I need to do any mixing or flaperon mode in my JR SX600? If so what advanteges does that have. Just a little lost on the wholw flaperon thing, do I need them, or just operate them as regular ailerons. Thanks in advance.
Ashley
Ashley
My Feedback: (90)
RE: flaperons for F4U
DO NOT try to use them as flaperons. Flaperons will only work with strip style, full span ailerons. If you try to your "barn door" style ailerons, as on the Corsair, as flaps, you will tip stall.
CA
if your using a y harness your not going to be able to mix anything. As stated the flaperon are only useful on full length strip ailerons. Even then it really a look what I can do set-up, only real advantage I've experienced is really tight loops which isn't something a warbird should be going. you'll be limiting the aileron travel and risking tip stall. Just leave it how it is and fly it.
If your stuck on using flaps do some kit bashing and put seperate flaps on. It's a real bear to do on a finsihed model
