Setup Du-Bro RC Kwik-Fill Fueling Valve
Hi guys,
Can anybody guide me with the setup of a Du-Bro RC Kwik-Fill Fueling Valve for my cowled GP RV4 ? I didn't come with any instructions....
How many lines leaving the fueltank, do I need to use ? 2 r 3?
Preferably a drawing of what needs to be connected to what ?
Thanks and best regards,
Biggles
Biggles
SC
RE: Setup Du-Bro RC Kwik-Fill Fueling Valve
It's simple, Biggles. The fitting that comes out of the valve at an angle goes to the tank. The fitting that comes out straight goes to the carb. This is your fuel supply line. If you are running a glow engine, attach the vent line to the muffler pressure as normal. If you're running a gasser, simply run the vent line out the bottom of the fuselage.
I hooked mine up as a 3rd line fill-only system on my Zenoah G-23. I ran the angled fitting to the tank as described and blocked off the straight fitting.
Dr.1
Dr.1
Thanks DrDriver;;;
So I understand that if you don't hook up the 3rd line as you did, one can just use 2 lines only leaving the fuel tank...? Correct?
Brgds,
Biggles
Brgds,
Biggles
Hi Biggles71,
I've used the Du-Bro RC Kwik-Fill Fueling Valve on a Sig J-3 cub for the very same reason you are on your airplane. I tried it the way that the valve had been intended but found it would leak air and cause my engine to go lean. I turned around and did what Dr1Driver did and have had good success since. So yes go with the three line fuel system and hook up the third line coming from the tank to the angle barb of the Kwik-Fill Fueling Valve. Simply plug the straight barb with a short piece of tubing which is pinched closed.
Cheers,
Cheers,
SC
That's right, biggles. Mine has never leaked air, but I have heard some do, possibly if connected inline like tschuey says.
Dr.1
Dr.1
My Feedback: (12)
SC
ORIGINAL: Dr1Driver
Dr.1
Dr.1
My Feedback: (24)
ORIGINAL: tschuy
ORIGINAL: Richard L.
Since you are going with a three-line system, why not use a fuel dot instead? It is simpler, lighter, fool proof, and leak free, and it doesn't require a special fueling probe.
ORIGINAL: tschuy
With all of my new planes I do. But the Du-Bro RC Kwik-Fill Fueling Valve was already mounted (hole drilled) so I worked around the problem....
Cheers,
