cs-64
cs-64
I was thinking about using a cs-64 servo on a 72" p40. I have a new airtronics z connector receiver and was wondering the the cs-64 servo plug will work with my receiver. On the tower hobbies web site the specs say that it is a universal plug but it doesnt specifically mention airtronics z connector like it does for the Hitec servos. Anyways I would appreciate it if I could get confirmation the cs-64 works with airtronics z connectors.
RE: cs-64
I assume the cs-64 is a standard servo. If it is, it will work fine. Most servos and all standard ones have 3 leads; Black = Neg. Red = Pos. (Blue, Orange, Yellow, White, Mauve, Turquoise, Buttercup, Tangerine...you get the idea) = signal. If the plug will not fit, you can modify the connector to fit the receptacle on the RX as long as those colors line-up correctly.
On airtronics Z stuff, the signal wire is on the left side as you look at the RX with the label up. They work with all standard servos. It's the OLD airtronics stuff which will give you headaches.
