3 line fuel with valve
KS
I am setting up a new plane and wanted to see if anyone has any warnings or suggestions.
Engine - 2 stroke tower .75
Muffler - Pitts
Fueler valve - great planes easy fueler
I was going to put the valve in between the engine and tank, but I noticed I would have to plug the overflow under the plane.
Would my setup in the picture work?
Do I have some of the lines mixed up? I wasnt sure if the line going to the muffler would be better off switched with the valve line.
No local hobby shop around, would like to finish this part soon.
thanks,
tracey
Muffler - Pitts
thanks,
tracey
My Feedback: (9)
RE: 3 line fuel with valve
It would work but I would suggest a few changes. Throw the fueler away and get a fuel dot. Also I would run the filler line further back in the tank. I like to have the filler clunk end 1/4" before the carb clunk starts. I also would cut the vent line down a little and extend it with fuel line. This makes the stopper easier to get in the tank.
Again it will work like you have it. These are just my preferences.
david
david
I totally agree with the fuel dot. I have had a couple of the quick fuel valves go bad on me. The result is a deadstick. Good luck.
"Keep 'Em Flying!"
Flak
"Keep 'Em Flying!"
Flak
