Building Table
My Feedback: (18)
LA
Building Table
I would like to read if anyone is using cork on their building/work table top. I toyed with the idea of doing so with square cut cork tile of some sorts. Any idea's or inputs? Have a better way that works for you when you pin down on the plans that seems to be relatively flat and true?
SC
RE: Building Table
I use 3/32" cork over ceiling tile. You can usually find the cork at Wal-Mart. Also check Lowe's and Home Depot. I love the surface it gives. Smooth with just a little "give". The whole table is a cutting board.
Dr.1
Dr.1
RE: Building Table
I built a nice building table. (I'll post a picture some day.) Nothing very fancy but it works great for me. The top is "reversable". It is made of 3/4in MDF. A sheet of Homasoat is attached to one side. When I'm framing and pinning, the Homasoat side it up. Otherwise I work on the hard MDF side.
My Feedback: (18)
LA
RE: Building Table
Hey thanks for trying to put up the picture. Also thank you to everyone for your replys. I did go to Walmart and saw exactly what you told me about. I almost bought the 12" tiles, till I saw the foam board in school supplies. I have 3 laid on the table and work great. I'm still sold though on your idea of the tile and it just may happen that I will go get that too!
RE: Building Table
dstonic:
I use Owens Corning "Foamular" 8'X4'X2" Insulation, from The Home Depot. it's softer than balsa, holds the pins well, and makes a great cutting surface, and when it wares out simply flip-it over and voila, resurfaced.
Precision & Consistency
RE: Building Table
ORIGINAL: carlbecker
I work off a glass ex bank door. I will never use anything else again.
Brad
OH
RE: Building Table
Where do you get your homasoat? I have been looking for some for a long time. Used to use it all the time but haveing trouble finding any lately.
