Winter Cold Engine Starting!
I'm going to start doing something that I've never done before. Winter flying. OK, those of you that live in the northern tier, what's your secrets for starting and keeping those cold 2c engines going in the cold winter. Over!
My Feedback: (8)
CO
I squirt starting fluid (ether) in the carb before I crank the engine. I've been told that WD-40 works equally well.
PS I have good luck with 20% nitro in cold wx
My Feedback: (8)
MO
The best thing I've found for starting cold engines is regular gasoline. Get a bulb from sullivan and squirt a few drops in the carb and it will start like a champ. Lighter fluid works ok but gasoline is the best.
My Feedback: (8)
CO
Gasoline
Oh, I almost forgot, adding gas (not to exceed 5%) to your fuel will help it run hotter in extremely cold weather and help it start quicker.
I added gasoline and acetone to my no nitro mixtures and it helped keep the plug lit.
My Feedback: (8)
MO
Ya you know the stuff you put in your everday driver, lawn mower, or what ever. I'm serious it works great no joke.
Just use normal saftey measures and common sense. If you have a helper to feed in the gas this is best.
If nothing else works at -20 windshield temp gas will. Believe me I was thinking what ? gas? when an old timer from our club showed us this trick we where amazed. The engine would start like it was 90 outside. Give it a try it's a lot safer than holding the engine behind the tailpipe of a car or truck. Have fun with your winter flying.
BTW our frozen fun fly is coming up on Jan 1 and believe me I will be using gas to start my engines. Have fun!
My Feedback: (206)
QC, CANADA
Remember those heating pads for sore backs. Connect them to one of those fantastic converters (12v to 120v) - available at stores like Canadian Tire Store up here in Canada and and connected in turn to a 12v battery will keep your engine warm to summer temperature. Engine well primed will start like in summer.
John
John
Hi, for some years I flown in the winter, -5°C, strong Wind and Snow. I take a propane gas burner and i make the cylinder and the head worm. Attention, don't burn your model. My model was a delta and the engine a 6.5ccm Webra. Ok, its crazy but its real!
Andreas
Andreas
