Servo question
IN
Servo question
I have an old cub with an Airtronics radio in it and the transmitter has gone south. Can I use the servo's that are in it and plug them into a JR receiver. Thanks in advance.
RE: Servo question
If the servos have the "Z" connector they'll plug right in and work fine. Servos with a "Z" in the model number should have the right connector. The wires will be black/red/blue which correspond to brown/red/orange. on JR.
If the Airtronics servos do not have black/red/blue wires, in that order, you have some work to do. I found the wiring diagram RCKen posted:
http://image.rcuniverse.com/forum/up...64/Fd92876.jpg
If your servos do not have the Z connector you'll need to move the wires in the connector so they are in the right order to match the JR receiver.
