plane flys weird
CA
plane flys weird
i flew my plane yesturday aftenoon. I discoverd that it doesn't fly straight. It keep moving left. Its not becasue that the wind. There was no wind that day. i checked the rudder and it seemed fine to me.. any clues??[&o]
RE: plane flys weird
What size plane and engine? But it sounds like you need R thrust off of your engine. Just put a washer or 2 on the L engine mount at the firewall ..... Greg
G'day Mate,
Is it yawing left or Rolling left, if rolling left, check your lateral balance, a heavy wing can cause the problem you are having, to check lateral balance in the air, trim plane to fly straight & wings level hands off, roll plane to inverted wings level & release aileron stick, if left wing drops add weight to right wing & visa versa, if it stays straight, no change required. The amount of right thrust needed is checked by flying straight & level, at full power & pull up into a verticle climb, if the plane goes left as it slows down it needs more right thrust, conversely if it goes right it needs less right thrust, if it goes straight, then no change required. This will help it to track better through loops & verticle stuff. If it yaws left, check fin & rudder are in line with fuselage centre line.
