sheeting problem..help
I have started sheeting an open structure craft with 1.5mm thick X 915mm wide balsa sheets. all has been going fine, now I dont know if this is because of a few days of damp weather but one of the sheets has sunken on one end and on the other has bulged up slightly.. I have an idea or two about fixing it but would like to hear if there is a proven method for fixing something like this
any suggestions appreciated
RE: sheeting problem..help
Hi, sorry about the lack of detail, as for it being in the fuse or wing..well the answer is both. the sheeting is on a Diamond Dust here is a photo of the problem. Hopefully the photo will show up the warping , it's in the sheet just behind the servo compartment
and yes I can get behind it , as I havent sheeted the bottom yet
yes it is the humidity that has caused this as it wasn't like this before, only after a couple of days of rain.. , if no other soultions are forthcoming I'll try that after my ideas fail, which is to get a heat gun and try to dry it or maybe even just re sheet that section(which I'd rather leave as a last resort)
I had some warped so bad that the only thing I could do was to cut it with a knife and trim out the bulge and use filler to smooth things up. I live in a dry climate, so usally this is not a problem.
