Pos/Neg Shift? Please Explain
Reply
Old 01-02-2003, 11:49 PM
Steve Guinn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pos/Neg Shift? Please Explain
I've got the low/high band..PPM/PCM pretty much understood, but what the heck is this shift stuff.
Steve
Steve Guinn is offline
Old 01-03-2003, 10:37 AM
Steve Lewin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From http://www.torreypinesgulls.org/Radios.htm (well worth reading)
In R/C "FM" there is only full modulation i.e., carrier shifted by 5 Khz or NO modulation (carrier only). R/C FM is identical to wireless data transmission "frequency shift keying" (FSK), at least the computer people don't pretend to be FM.
The Futaba, Hitec and Tower Hobbies camp are NEGATIVE shift (carrier - 5 Khz)= ON. The Airtronics/ JR camp are POSITIVE shift (carrier + 5 kHz)= ON. Carrier only is OFF for both. For example an Airtronics PPM frame, with all servos at Neutral, would start with 72.075 MHz (ON) for 1.5 m then 72.070 MHz (OFF) for 0.5 ms repeated for 2 - 9 servos and wraps up with 2 ms at 72.070 (OFF) synch.
HTH - Steve
Steve Lewin is offline
Old 01-03-2003, 09:48 PM
Steve Guinn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Steve. Explained very well.
