Need help Setting up the B & B smoke system.
My Feedback: (28)
TX
Ok for the most part i can set up everything on my own but on the instructions it says to drill a 1/4" hole in the crank case so i can put in one of the peices. All I need to know is where in the crank case should i drill it and also what should i be careful of. If you have pics i would greatly apreciate it.
Engine: US 41 gasser
Plane: 1/3 Pitts Bipe
Thanks, Greg
Thanks, Greg
