props ?
RE: props ?
The OS46AX's recommended prop is an 11x6.
Changing from a 10x6 to the recommended prop ought to give you better performance. It'll probably pull the airplane faster and with the extra fan area, should climb better.
PA
RE: props ?
Try A APC Porp Of The Same Size.i Like Them Better Because They Do Not Flex As Much.On The Bad Side They Are Not As Forgiving In A Crash.I Still Like Them I Just Learned To Crash Well
