Sky Cutter V2
Sky Cutter V2
I have a flying thingz Sky Cutter V2 it says 40-46 size motor in the kit instructions I put a .46 evo on it and it seems like it just does not have enough power. Does anyone else have one of these that migh point me in the direction of a motor size better suited for this plane?
RE: Sky Cutter V2
I had that same problem. I started my lawnmower off on an OS 70 Surpass and thought it was not enough. So I considered a saito 91 but I just went striagit to a saito 100. Even with a saito 100 on it, It still didnt seem like it had enough powere to do much of anything to me at least. I believe that it needed every bit of that saito 100, the only downside is that the 100 rips the whole plane apart. Each landing I have with it loosens up more stuff and long story short I cant fly mine anymore becuse the handle is broken off in the foam, the mower deck is coming unglued and the bals fuselage box is coming loose at the seams. I have thought about beefing up the mower handle but dont know how just yet.
david
david
