Covering over wood areas exposed to fuel
Several repairs I have made and tried to recover have been unsuccesful as wood areas around the repair have been exposed to a minimal, but just enough fuel that got under the covering. What are my options in trying to recover aside from tearing out all the affected wood and starting from scratch? I am using monokote as my primary covering but am not opposed to trying others.
RCU Forum Manager/Admin
My Feedback: (9)
RE: Covering over wood areas exposed to fuel
The first thing you need to do it remove the fuel from the wood. Pick up a product called K2R, it's a carpet cleaning solution. Completely expose the soaked wood. Use your heat gun to heat the wood, as it heats you'll see oil start to seep out of the wood. At this point spray the area with the K2R and wait for it to dry (turn to powder), then brush off the powder. Keep repeating this cycle until you there is no (or very little) oil coming out of the wood when you heat it. Don't get in a hurry as this can take awhile. After you have as much oil out as you can then you'll need to seal up the wood. I use 30-minute epoxy. Put a blob of epoxy on the wood and use your heat gun to thin it out, use an epoxy brush to "paint" the affected wood with the thinned epoxy. Once the epoxy dries then you can recover the area affected. Others my have different materials to seal the wood, but I use epoxy.
Hope this helps
Ken
Hope this helps
Ken
I use K2R OR cornstarch to absorb the oil in the wood. As Ken stated, itWILL TAKE several sessions to remove the oil. At this point I use SIG "StixIt" to seal the area. StixIt is brushed on and once it dries the heat from the iron activates the glue.
I use this exclusively in areas where I can not wrap the covering (Windows, etc ). I have found that the wood will let go before the adhesive in this does. To remove the covering from a StixIt area, just apply heat while lifting it up/off.
