Painting
RE: Painting
You can paint over Monokote. Monokote is fuel proof though.
If you want to paint over monokote (or any film covering), use a 3M "Greenie" pad (or 0000 steel wool ) to scuff the surface so it has a "frosted" appearance. Clean the area TWICE using alcohol AND FRESH CLOTHS for each cleaning. Then prime and paint.
FWIW: Balsa can be covered with fiberglass, silkspan or tissue also as a base for the paint . The purpose is to keep the changes in humidity from causing the balsa to "move" and crack the paint. The "old fashioned" way was to seal the balsa with a talcum powder-clear dope mix, usually a couple of coats sanded between coats.
RE: Painting
Use fabric if you really want to paint a plane. Monocote can be painted if scuffed like mentioned, but it still isn't a good looking finish. Monocote isn't intended to be painted. Fabric on the other hand is and can be done very well. I do it on all my planes that are 60 size or larger.
Gibbs
Gibbs
