Help a fellow modeler keep his wife from killing him!
Well here it is i need help fast! I had a saito 72 in the formal dinning room on the table. when i carried it out side it started dribbling nitro on the carpet. Well i would like to know what i can do to get it out fast! Its cool power 15% the dribble line is about 10 ft long.
TX
RE: Help a fellow modeler keep his wife from killing him!
Use k2r spot remover - the powder absorbs the oil. You will have to probably do a couple of applications and vacuuming it up.
ya she hasnt found it yet the only thing i have on my side right now it she is sick and hasnt made it past the living room in 2 days.
Hi,
Sprinkle the spots with a liberal amount of corn starch (you cook with it, its like flour), rub it in and let sit for 4 to 8 hours and then vacuum up. It will absorb the oils. If its real bad, you may have to do it twice. It also works for grease and oil.
Good luck!
Fly4Fun,
Wayne Miller
Good luck!
Fly4Fun,
Wayne Miller
TX
Tuffstuff, yellow and red can, automotive section at wal-mart. Its a cleaner we use it to clean customers trucks when we get grease and oil in them. $2.50 or so a can. spray let soak scrub out, I know I use the same fuel.
Your screwed. Nothing will take that oil out of the carpet.
Better just take your cot out in the garage and plan on a cold winter. [sm=lol.gif]
Only chance of survival is too send her away to the spa for the weekend and "surprise" her with new carpet when she returns.
Tuff Stuff is the winner. I picked some up and it took the fuel out. i couldnt belive it.!!! Thanks for all the input on this one!
You have several options:
1- induce her to RC modelling (worked with my wife...) and everythig will be forgiven
2- point the dog (or the cat, or the parrot)
3- Ignore the spot... spot? Idon´t see any spot there...
4- "Look; is the same color than your eye's make up!!!"
5- get another wife (if needed)
Good luck
Guille
Good luck
Guille
Location: Hamilton, Scotland & La Roche Bernard, France
Buy a new carpet.. take samples of fuel, epoxy, oil, paint etc to your carpet store and get something in those colors.
I did that in my spare bedroom.. you should have seen the salesman's face when I explained I wanted an epoxy-colored carpet. Worse still.. you should see what I ended up with [:'(]
Regards
Scott
Regards
Scott
