8.8lb plane with a .61, how will it fly?
Reply
Old 10-07-2006, 12:00 AM
alexcc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 8.8lb plane with a .61, how will it fly?
Hey guys just finished building my phoenix Yak 54 and the thing was REALLY tail heavy so I had to add quite a bit of weight to the front. Anyway after I added everything and checked the CG again it felt really heavy, when I weighed it I realised it weighed 8.8lbs. No too clued up on what the weight should be but it is flying with a .61 GMS and pitts muffler. I am worried that it is going to be really sluggish, does anyone have any idea how a .61 with a claimed 2HP would pull 8.8lbs?
alexcc is offline
Old 10-07-2006, 01:41 AM
ArCeeFlyer
ArCeeFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 8.8lb plane with a .61, how will it fly?
As far as thrust to weight ratio, that seems pretty heavy to me. I just finished rebuilding a broken .40 size Magic Extra and beefed it up a lot. It got very tail heavy and I put a Super Tigre .61 on it to make it balance. It weighs 7 lbs with a full tank. It's normally a 5 lb plane. It actually flies great but does feel heavy. The wing loading jumped from normally 19 oz/sqft to 23.5 oz/sqft. but the thrust to weight is still hanging in at 1.7 with a 12.25 x 3.75 APC prop turning about 13,500 rpms. That prop would only give about 1.4:1 thrust to weight on 8.8 lbs at that rpm. If your wing loading is still down to 20 oz/sqft or less, it should fly fine otherwise, but not the best for 3D stuff.
ArCeeFlyer is offline
Old 10-07-2006, 06:31 AM
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I fly a 6.5-pound Kougar with a .50 engine and it is flies fine for me but probably feels heavy to others.
Bill
BillS is offline
Old 10-07-2006, 08:49 AM
aerowoof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how well it flies will depend more on the wing loading,a brick will fly with enough horsepower but will it do manuvers without falling out of the sky.you may be okay at full throtle but watch for snapping when you cut the power espeacially in turns and while landing.will probably have a high stall speed.scale planes fly close to 10 pounds with a .61 but have problems at takeoff and landing.
aerowoof is offline
