Reload this Page >
NiCd peak charger as foam cutter power supply
Reply
Old 10-08-2006, 12:18 PM
topwinguk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default NiCd peak charger as foam cutter power supply
A couple of months back there was an article/video clip of foam cutting using an Astro 112 NiCd peak charger, on E-zone. This looks like a neat method, as once you adjust the temp for a particular cutting wire and note the current, then you can set that current on the charger for any length of cutting bow that you ue in the future. Anybody tried this and have any views on the method i.e. use of other makes of charger other than the Astro 112. I have used my Astro 110 with sucess although the unit LCD display denotes a "no battery" statement which cancels when the start butten is pressed.
Tony
topwinguk is offline
Old 10-13-2006, 08:53 PM
jeremiah__brown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NiCd peak charger as foam cutter power supply
why not just hook a lire to a good soldering iron.
jeremiah__brown is offline
Old 10-14-2006, 11:20 AM
Deadeye
Deadeye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jeremiah__brown
Simply hooking up a wire to a soldering iron will not produce enough throughout the wire to properly heat it enough to cut the foam.
Tony, try posting this question in the scratch building forum. You will get more educated answers in there, I bet.
Deadeye is offline
