Checkerboard covering?
Reply
Old 10-08-2006, 06:20 PM
mobflier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Checkerboard covering?
Is there a company that makes a covering that is checkerboard? I was told you can weave covering, but that sounds quite time consuming. Any help or suggestions would be appreciated.
mobflier is offline
Old 10-08-2006, 06:33 PM
jsn
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Checkerboard covering?
http://www.horizonhobby.com/Search/D...squares&CatId=
Good stuff... easy to work with and so much simpler than cutting a bazillion squares
John
jsn is offline
Old 10-08-2006, 07:11 PM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've used Ultracote checkerboard in a couple of different size checkers and different color combinations. It works great.
da Rock is offline
Old 10-08-2006, 09:17 PM
mirwin
mirwin's Avatar
ORIGINAL: darock
Will Ultracote stick to Monokote?
mirwin is offline
Old 10-08-2006, 09:57 PM
jsn
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes it will... you can't use trim solvent with ultracote so you must iron it down. Utracote applies at a lower temp than moneykote so that's not a big deal... it also won't out gas like moneykote so you don't end up with a bunch of air bubbles as long as you dont'trap air as you iron it down. laying the trim piece down with some windex and working it smooth with a squeegee before hitting it with your iron helps.
John
jsn is offline
Old 10-08-2006, 10:11 PM
mirwin
mirwin's Avatar
ORIGINAL: jsn ". . . Yes it will... you can't use trim solvent with ultracote so you must iron it down. . . . John
Okay, thanks, John. I've used monokote quite a bit, but never tried ultracote.
Mike
mirwin is offline
Old 10-09-2006, 07:40 AM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are going to be surprised and pleased with the Ultracote.
da Rock is offline
Old 10-09-2006, 12:06 PM
voyager_663rd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Depending on how "exacting" you are, you could also use checkerboard shelf liner (back peels off, adhesive is already on the paper) sold in stores like Dollar Store. A buck for 10ft and sticks like crazy. Did that on my somethin' extra and it looked great.
voyager_663rd is offline
Old 10-09-2006, 06:31 PM
mobflier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for all the input.
mobflier is offline
Old 10-14-2006, 11:25 PM
expo
My Feedback: (20)
expo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just my humble opinion.... small and medium checkerboard patterns fade out to gray at a distance.
I've used Ultracoat 2" black and white checks and it was unrecognizable as such over 200' away when placed on the bottom of the wing unless the sun was reflecting off of it.
The only pattern I've been able to recognize at a distance was the red and white bottom of a Ucando with it's huge checkerboard pattern.
expo is offline
Old 10-15-2006, 07:42 AM
Gringo Flyer
My Feedback: (18)
Gringo Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with Expo. I wouldnt use checkerboard to help distinguish the plane in flight. It does fade to grey. However on the ground it looks great. I think a Ryan STA looks some kind of cool with the checkerboard.
I would do checkerboard on a plane now that I have a little more confidence in my flying and dont need a super wide trainer type strip beneath the wing to know if the plane is up or down! A year ago it was a different story.
So mob that is good advise from expo.
Gringo Flyer is offline
