exhaust extension ?
exhaust extension ?
I'm looking for an exhaust extension.Something that will stay bent and not that heavy thick blue tubing.Maybe something tin or aluminium.Tell me what your using wether its from an rc manufactor or home depot.Thanks
RE: exhaust extension ?
Copper pipe works great. It's easy to work with. It's cheap. Lowe's Home Improvement in the plumbing supplies............
Some mufflers' pipes are a slip fit, some require a bit of work on the copper pipe. J&BWeld holds good. You can also back it up with a small screw. The result is bulletproof.
My Feedback: (10)
Depending on the Diameter, Tower Hobbies sells 'Macs Exhaust Diverters', Aluminum and in several sizes; here is link to one
http://www2.towerhobbies.com/cgi-bin...?&I=LXZ663&P=7
