Spraying Clear Coat
Reply
Old 10-12-2006, 08:47 AM
chuck l
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Spraying Clear Coat
I've finished my first big spray painting job and the finish came out ok. I'm debating whether to clear coat it or not. It's been painted with Behr's semi gloss interior paint using a Porter Cable HVLP gun and the plane is gas, not glow. What would be the reasons to clear coat it? If I clear coat it, I would like to use Varathane waterbased poly unless someone has a better suggestion in a waterbased product. Does it have to be thinned? How many coats and how thick should the coats be?
Any advice would be appreciated.
Chuck
chuck l is offline
Old 10-12-2006, 09:10 AM
saramos
saramos's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Spraying Clear Coat
I recently finished a latex paint job on my glow plane. I used the Varathane Diamond Spar Urethane. This was a necessity on a glow plane, but I understand that it is not such a conscern with gas. It will still add a little more scratch resistance, but will add more weight. I applied it straight from a spray can. If you do choose to use it, be sure to let the latex dry for about a week (or even two if you have the patience).
Scott
saramos is offline
Old 10-12-2006, 09:12 AM
saramos
saramos's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oops, double posted.
Scott
saramos is offline
