OS .46 LA carb question
Reply
Old 10-19-2006, 09:55 AM
kilmerelrc
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS .46 LA carb question
I have an OS 46 LA with a remote needle set up. For install on a new plane it would be helpful if it did not have the remote needle and just had a needle at the carb it self. Does anyone know if they make a carb/needle assembly for the O.S. 46 LA and if so where to get one. If not, are there any companies that make hop-up or replacement carbs for the O.S. 46 LA that I could ckeck on. Thanks Kilmerelrc
kilmerelrc is offline
Old 10-19-2006, 03:36 PM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS .46 LA carb question
Hi!
Just buy a new needle (whatever brand) and place it where ever you want! I mostly use MVVS needles as they are good and not too expensive.
Regards!
Jan K
Sweden
ID:	543989   Click image for larger version
jaka is offline
Old 10-19-2006, 06:23 PM
delman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you want a front needle carb you need to get a replacement carb used for the os40fp. I believe they are still sold new as well as used ones. It's a 3A on the OS website.
delman is offline
Old 10-20-2006, 07:24 AM
kilmerelrc
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for all the input. I actually found a replacement carb from the cumpany that makes Perry Pumps. It will fit in the mounting hole on the engine and actually has a slightly larger inner bore than the original carb from OS. I ordered one and will see how it works.
Kilmerelrc
