OS BX-1 Carb
Reply
Old 10-19-2006, 01:26 PM
freebird1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS BX-1 Carb
I have an engine that an old friend gave me. It is an older engine, but has seen little use. It is a OS bx-1 not a bgx-1. It has lots of power and seems like a real good engine. It has a 7m carb on it and to say the least in all my years in the hobby have I seen a low end needle setting like is on it. It is flooding it and I was hopeing someone could tell me how or where I can find out how to set the low end. I checked OS web site and can not find anything on the 7M. It has three adjustment plus the high end. Help!!!!
freebird1 is offline
Old 10-19-2006, 05:54 PM
dbacque
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS BX-1 Carb
The low end is adjusted with the screw on end of the barrel opposite from the high speed needle. You will have to loosen the nut in the center of the barrel, then the screw will adjust the plate under the bolt. The plate has a pointer to a reference mark with +/- on the barrel itself. Be sure to lock the adjustment back down when you finish.
It's a great engine!
Dave
dbacque is offline
Old 10-20-2006, 12:27 AM
freebird1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks!!!!!
It will take a little tinkering with, but I beleavI see what you are saying.
