Smoke System, i need help..
Reply
Old 10-22-2006, 05:36 AM
juvaknin
juvaknin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Smoke System, i need help..
hi guys,
i put my question also here... hope anyone can answer it...
i want to use Smoke system on my Airplane..
i'm going to use "Sullivan" sky-writer Pump..
i have question about the Installation,
i "must" use this "Antisiphon valve" on the muffler line ?? (see in the picture).
another question, what you doing with the "Vent line"?? (see in the picture).
i have 3 lines...
one - connected to pump
sec - using for "Fulling the somke tank" and i have plug for it..
thrd - it is the "Vent line".. where to put it? the smoke liquid won't leak from it????
Thanks for your time to answer me!
juvaknin is offline
Old 10-22-2006, 06:24 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Smoke System, i need help..
Yes, you must use the antisiphon valve - they should have supplied that. If they did not, you can use a one-way check valve from the Local Hobby Shop.
The vent line just exits the airplane so that any overflow will spill outside the plane
MinnFlyer is offline
