On-board Glow System
Reply
Old 10-26-2006, 04:05 PM
ductedfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default On-board Glow System
I was wondering where I could find an on-board glow system. I checked Tower and can't seem to find one. Are they a thing of the past??? Thanks in advance for all of the info...
ductedfan is offline
Old 10-26-2006, 04:27 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: On-board Glow System
If you are interested in building one, one of my visitors designed one and sent me the information.
It can be found here: http://www.geistware.com/rcmodeling/articles/obgpd.htm
ORIGINAL: ductedfan
Geistware is offline
Old 10-26-2006, 05:48 PM
saramos
saramos's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On my TF Spitfire, I use a wheel collar on my throttle linkage which activates a microswitch controlled 1.2v NiMH battery. It kicks on when the throttle is all the way down and the throttle trim is centered. It goes off when the trim is all the way down and the throttle is down. It also turns off at 1/2 throttle or higher. Not fancy, but cheap.
Scott
saramos is offline
Old 10-26-2006, 07:27 PM
Bud Faulkner
Bud Faulkner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here ya go.
http://www.electrodynam.com/cgi-loca...5b3+1163060024
Bud Faulkner is offline
Old 10-26-2006, 07:37 PM
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have three of these; SuperGlo by MPI. www.maxxprod.com.
khodges is offline
Old 10-26-2006, 07:39 PM
Newc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got two of these, one on each engine of my Nomad.
Newc is offline
Old 10-26-2006, 07:47 PM
Ed_Moorman
Ed_Moorman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The commercial on-board glows work well, but are fairly expensive. In my experience they cost from $50-$75.
When my buddy and I started flying seaplanes, we wanted an on-board glow so we made one. You can buy a remote glow hook up from Maxx Products for about $12-$15. We added a micro switch from Radio Shack. The switch was either set-up on the throttle servo or on another servo and mixed to the throttle. We used our standard glow ignitor for power. It was easy to use and charge. It isn't very elegant or hi-tech, but it worked every time.
Ed_Moorman is offline
Old 10-27-2006, 04:32 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why do you need one? It's just a weight burden to your plane?
rajul is offline
Old 10-27-2006, 05:55 AM
LuftwaffeOberst
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rajul
Exactly... plus the guys at my club had problems with it. They suggested that I'd leave mine off the plane. JMO
Peter Dowling aka Luftwaffe Oberst
AMA District II # 865404
Aero Modelers Club
Pulaski, NY
LuftwaffeOberst is offline
Old 10-27-2006, 09:17 AM
saramos
saramos's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Whether to use one or not, of course is a personal choice. I went with onboard glow for several reasons. First, the engine I used recommends the use of a remote glow because the glow plug is so close to a large prop (15" 4 blade or 18" 2 blade). Second, I wanted to avoid holes on the exterior of my plane. Third, it is a bit added protection against a dead stick. If the glow fails in flight, it's no worse than having no glow at all. Lastly, the placement of the battery in the nose helped in ballancing the plane. If I had not used an onboard glow, I would have had to add more ballast to ballance the plane anyway.
I will agree that it adds another item you have to set up, adjust, and maintain. In my case, I thought the effort was worth it.
Scott
saramos is offline
Old 10-27-2006, 09:39 AM
Bud Faulkner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What saramos said.
I have mine in my DPM super cub with an O.S.160FT I don't like unnecessary holes in the cowl.
Bud
Old 10-27-2006, 03:35 PM
Newc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That pretty much sums up my reasons as well, but I also add that with a twin I don't want a single engine deadstick if it is easily avoidable, my engines (YS FZ63S) are mounted inverted and therefore - also due to being four-stroke - more prone to flame out conditions, my plane is a 104" PBN Nomad and I really don't want a deadstick out on the lake since I haven't yet perfected the art of walking out to my plane on water.
Besides, I like to try new things with every plane I build, and it's one more learning exercise.
Newc is offline
Old 10-27-2006, 05:59 PM
saramos
saramos's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can definitely see the further benefits in a seaplane and/or twin! I also see that the 'Ls' in balance were out of balance in my last post!
Scott
saramos is offline
Old 10-27-2006, 07:11 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I see your points. You may want to check out the intelligent glow driver from Nelson http://www.nelsonhobby.com/electr.html
rajul is offline
Old 10-28-2006, 02:39 AM
kqutob
kqutob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use the Expert on board glo on three of my planes .So far no troubles
http://www.horizonhobby.com/Products...ProdID=EXRA550
kqutob is offline
