Self Tapping Screws and #4 Screws Question
Reply
Old 11-05-2006, 12:14 AM
Palmdizzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Self Tapping Screws and #4 Screws Question
ok - Im a newbie. Here is my Engine mount for my AP .09 Hornet:
http://www2.towerhobbies.com/cgi-bin...?&I=LXLW83&P=0
I need the following below? Self Tapping Screws? Arn't those for plastics? How am I going to drill those into the mount? Also - can I get those at any Ace Hardware or something?
And #4 Size screws - are those 3x12's or something? I'm confused - Any ideas/questions/concerns would be helpful - thanks!
REQUIRES: Four #4 size Screws to Install Mount to Firewall
Four Self-Tapping Screws to Hold the Engine to Mount
Palmdizzy is offline
Old 11-05-2006, 12:26 AM
super tigre
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Self Tapping Screws and #4 Screws Question
You have to mark the location of the holes on the mount then drill the holes for the screws.you should be able to find screws at lowes home depot etc. hope this helps.
super tigre is offline
Old 11-05-2006, 11:04 AM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Palmdizzy: If you want to use the self-tapping screws (designed for sheetmetal, actually) you need to drill a pilot hole in the mount. That means a hole smaller in size than the screw, but large enough to allow some relief as the screw cuts threads while being inserted into the mount.
For a #4 screw I would use a 5/64 drill bit for the pilot hole.
Kmot is offline
Old 11-05-2006, 01:32 PM
DavidAgar
My Feedback: (107)
DavidAgar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can also mark the screw centers and drill and tap the mount for 4/40 screws. You can get a 4/40 tap at most hardware stores. Good Luck, Dave
DavidAgar is offline
