carving aluminum spinners
Reply
Old 01-21-2003, 07:21 AM
Andrew_S
My Feedback: (12)
Andrew_S's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default carving aluminum spinners
How do u carve out the slot in an alum spinner so it fits the prop..Andrew
Andrew_S is offline
Old 01-21-2003, 03:24 PM
LesUyeda
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use my Dremel tool sanding drum.
Les
LesUyeda is offline
Old 01-21-2003, 04:16 PM
Goinstraightup
My Feedback: (26)
Goinstraightup's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, that's the best. Start with a small router bit like 1/8 dia. Try to not let it get away from you. Then go to 1/4 dia. drum. If you have a really big prop, the 1/2 inch dia. drum will make it look nice.
Goinstraightup is offline
Old 01-22-2003, 04:51 AM
linclogs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's photos of how I've done it on a Great Planes 2.5" spinner (I think this is the same way LesUyeda and Goinstraightup describe it).
Make a template of the basic shape you want to cut. Use the existing holes to line up the template so the new holes are exactly opposite of each other on the sides of the spinner. Use a permanent marker (like a "Sharpie") or better yet, carefully scribe around the template to mark the outline to cut out.
I used Dremel grinding stones (size depends on diameter of area to be cut out). I use the sanding drums for final smoothing (along with appropriate needle files).
Always check the spinner on a balancer and adjust as needed.
The spinner shown is a Great Planes 2.5" spinner on a US Engines 41cc engine. I'm going to use this on a quarter scale J-5 Enterprises Stinson Voyager 105. The plans show a spinner with a 2.5" diameter and a 1 13/16" depth - an extremely "squat" spinner.
I searched all over for a similar spinner and the closest thing I came up with was a Tru-Turn FAI spinner, which measures 2.5" in diameter and 2.125" in depth. But information on Tru-Turn's web site states that particular spinner will take "Up to a Zinger 12 in. /12p Two Blade" prop. However Tru-Turn offers a "Special Slotting Option" where, for a fee, they will enlarge the slots to fit your choice of prop. As the Voyager plans call for using a Quadra type engine, which is basically what the US Engines motor is, and that engine calls for using an 18 - 8 through 18-12 prop, I emailed Tru-Turn to ask if their 2.5" FAI spinner could be slotted to fit that size prop. This was their reply:
"That 2-1/2" FAI Spinner is too small to safely slot for an 18" Prop. The
2-1/2" Standard MAY have enough meat to it for an 18" prop's slots, but I
would have to try it to be sure. We will not ship anything out of here that
may be questionable on structural integrity
Ric"
Again, the Stinson kit called for a Quadra engine with a 2.5" spinner, so I didn't feel what I was asking for was an unheard of proposition. Nevertheless, I was faced with purchasing a spinner and enlarging the holes myself.
linclogs is offline
Old 01-22-2003, 04:30 PM
jgiles-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great idea on using the template!
It's not fun having to go buy another spinner and start over because your holes are offset. Not that that's ever happened to me.... :-)
I always wondered why they come with such SMALL holes from the manufacturers? Granted you can't add material, but how many people are putting large aluminum spinners on planes with less than 10" props?
jgiles-RCU is offline
