Power Draw
WI
Power Draw
Hello Friends at RCU,
I am using a program called power draw for drawing up some foamy plans for this winter. Do you know how to convert the file to .pdf. The file comes out as .pwd when I save it. Now I need to convert it to .pdf. Any suggestions?
Shane
Shane
CA
RE: Power Draw
Shane,
You need a program so you can print to a pdf.
I have one called PDF Creator. I got it from sourceforge.net.
You install it as a printer.
There are others out there, try a google search.
Good Luck,
KW_Counter
Good Luck,
KW_Counter
