Whip Antenna with receiver antenna
CA
I am flying eurosport with 14mz. I have located receiver antenna inside the fuse which i do not feel comfortable. I see many jet pilot using whip antenna. I'd like to use one too. My problem is that i really don't want to cut original length of receiver's antenna and 14MZ receiver antenna is not that long. I want to keep the same length if i can.
Do i have to cut the original length of receiver's antenna in order to use whip antenna??? if so, what is the maximum length and minimum length of original antenna wire??
Please help......
Thank you !!!
Please help......
Thank you !!!
