Flying Wing Information
Reply
Old 01-27-2003, 03:52 PM
mjse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Flying Wing Information
Hi
I need some information about engine powered flying wing model such as design , theory , trimming , construction , plan , airfoil ...
Any help would be appreciated .
mjse
mjse is offline
Old 01-29-2003, 04:37 AM
whstlngdeath
My Feedback: (15)
whstlngdeath's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Flying wings
Here's a weird but interesting article:
http://members.ozemail.com.au/~flyingwing/vern/
Look into the Zagi's models, too. Good luck,
Jesse
whstlngdeath is offline
Old 01-29-2003, 09:53 AM
mjse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mjse
mjse is offline
Old 01-29-2003, 01:07 PM
VoughtF4U
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have flown several different flying wings. Some were specifically designed airfoils and models for flying wings, others were just wing parts I converted from conventional models that had busted up fuselages. Everything from straight wings, tapered wings and swept wings...
I have noticed that the wings designed specifically for flying wings only have maybe a 5% advantage over a regular models wing flying as a flying wing. They all fly well as flying wings, just some designs take a little more trimming. Some are more sensitive in pitch than others and some are more critical of where you set your CG but just about any design will fly as a flying wing.
My suggestion is if you are thinking about building one, go with whatever is easiest for you right now and learn from you first one. Zagi flying wings are a cheap and easy way to get into flying wings and electrics. They are fast ans easy to build and fly great. You will learn from them about CG placement and too much elevator snapping them.
Just about any model of an Me-163 is a great flying wing even though it has a fuselage. MAN has a .40-.60 size set of plans for about $20 that is very easy to build, flies fantastic, and looks awesome in the air.
Good luck with your project.
VoughtF4U is offline
Old 01-29-2003, 04:28 PM
monocoupe
My Feedback: (40)
monocoupe's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Another Flying Wing
Here's another one to consider, that I can recommend:
It's called the "Winglet" and the plans are available from MAN. I built one of these, and they fly really well. The plans show optional speed brakes....use them! It's a bear to slow down enough to land without them. It has a 72" wingspan, and takes a .40 pusher. There is a picture of mine in my gallery.
Cheers, Nigel
monocoupe is offline
Old 01-31-2003, 08:19 PM
mjse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
VoughtF4U , Nigel , thanks for good info .
mjse
mjse is offline
Old 01-31-2003, 09:46 PM
LarryC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mjse,
Go to www.deltavortex.com
There are some links from that page that might help.
Larry
LarryC is offline
Old 02-01-2003, 06:16 PM
mjse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Larry ,
Thanks for info .
mjse
mjse is offline
