Dubro Swivel Ball Link Question
NE
Using 4-40 swivel ball links for the first time, on a 1/3 Pitts.
Just want to verify that I'm putting these together correctly.
The screw goes through the swivel,
then the spacer,
then through the servo arm,
and finally the nut gets tightened right up against the backside of the servo arm?
Is that right?
Just seems wierd to be tightening the nut up against a servo arm, which will be in motion.
Am I missing something here?
then the spacer,
Is that right?
NE
RE: Dubro Swivel Ball Link Question
So the nut does indeed go right up against the servo arm.
That's the part I was raising an eyebrow about, but fair enough.
Thanks guys.
Thanks guys.
