New mod on 4*60 (Have Pics Now)
Reply
Old 02-02-2003, 05:42 AM
ebeygin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default New mod on 4*60 (Have Pics Now)
Hi!
I have just started on a new mod for my four star.. this modification is more to increase the visual aspect, then the performance of the plane, but with that in mind, I really need to know, how it will affect my plane's performance and aerodynamics.
The fourstar's fuselage, is flat on the sides.. this gives it a very plain look.. sort of like a box.. only the top is curved a little for the eye...i want to curve the sides also.. so the fuse has a more rounded look to it.. check out the picture.. i'm not a good drawer.. but this is just to get a sense of what i'm doing...
My question is.. how will this affect the planes aerodynamics.. and will there be any noticable changes in it's flight charecteristics?
thanks for your input..
-eugn
P.S... it won't add a lot of weight, since i'm curving thin balsa over thin little ribs that i'll glue to the sides of the fuse.. same technique as used for the top of the fuse..
ebeygin is offline
Old 02-03-2003, 09:26 PM
ebeygin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default :(
how come nobody is answering?
eugn
ebeygin is offline
Old 02-04-2003, 01:30 AM
Al Stein
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don' t think you'll see any change in performance.
The only thing I could picture your change affecting would be something that relies on airflow being stifled as it "tries" to flow around the flat-sided fuselage -- so knife-edge might suffer, but the 4*'s not really a great knife-edge plane anyway is it? The plane may have a little less drag with the rounded sides, but I really doubt that it would be enough to notice.
While you're at it, you can probably also change the shape of the tail and wingtips without affecting performance (if you have a mind to). Just keep the same areas and incidences. A nicely kit-bashed 4* can produce a better flying sorta-scale version of an awful lot of low-wing full size planes, too.
Al Stein is offline
Old 02-04-2003, 02:43 AM
Ed_Moorman
Ed_Moorman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bashed 4-Star
A bashed 4-Star flies just as well as the original. Mine knife edges all day long. Magnum .91XLS with Ultra Thrust muffler
Ed_Moorman is offline
Old 02-04-2003, 06:20 PM
ebeygin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default thanks
thanks guys..
i didn't think it would make any difference either...
i've got another question.. about the weight.. how will the extra weight affect it.. but i'll post that in a seperate topics..
nice looking plane ed_moorman.. it looks amazing!
-eugn
ebeygin is offline
Old 02-04-2003, 06:44 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You may be making this sound easier than it is. Blending rounds into flats is not as easy as it sounds. Give it a try, but be prepared to either do a lot more work than you think, or rip it all off and go with the original idea.
MinnFlyer is offline
Old 02-04-2003, 07:08 PM
Heath
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ed,
I LOVE what you did with the wingtips, exactly what I had in mind to do for mine. Got any tips or pics on how you did it?
Heath
Heath is offline
Old 02-05-2003, 07:03 AM
ebeygin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To MinnFlyer:
Actually.. I already did it.. it took me about 3 hours.. the result is amazing!!!
and it wasn't hard at all..
frankly.. i don't find building hard..it's a very simple process actually.. as long as you are very carefull.. slow.. and follow instructions carefully..
as for the mods.. i used the top deck as an example to make the sides.. my sides are oval from top and bottom.. more oval at the cowl.. less oval by the trailing edge of the wing.. .. AND also.. thin in the beginning and become thicker towards the cowl..
believe it or not.. but when i wet that balsa down.. it bent very easily...
-eugn
ebeygin is offline
Old 02-05-2003, 07:30 AM
ebeygin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default here is how it look
it looks a little better in real life..
my 640x480 webcam doesn't really show that much detail...
this is what I ment by my explanation above..
is this not too much weight?
ebeygin is offline
Old 02-05-2003, 07:34 AM
ebeygin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here is the uncompleted side
ebeygin is offline
Old 02-05-2003, 07:35 AM
ebeygin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
from top...
ebeygin is offline
Old 02-05-2003, 07:36 AM
ebeygin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
from bottom..
ebeygin is offline
Old 02-05-2003, 02:52 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice Job! I am impressed.
Welcome to the Builders Brotherhood!
Old 02-05-2003, 03:39 PM
RLDIII
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree, nice job. The rounding should really "dress up" the Four Star.
Al, I would have to disagree with your comment about the knife edge of the Four Star (at least the .60 size). With the stock dihedral, mine is actually one of the best knife edgeing planes I have. However, I did clip the wing one bay on each tip and also have a YS .91AC on it, along with very tight pull-pull hardware on the rudder. That may have something to do with it!
Y'all have fun now!
Lee
RLDIII is offline
Old 02-05-2003, 05:17 PM
ebeygin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks..
that was the whole purpose.. to dress it up...
when you look at the plane below.. standing at it's side.. the fuse looks nice and proportional.. but when you stand right above it..
its very thin...compared to the span of the wings..
by rounding the fuse.. it automatically becomes more like a real plane..
i used the extra 300 as my example.. it's fuse is nice and round.. and that's how they should be..not square..
-eugn
ebeygin is offline
