Carbonfiber control links?
Reply
Old 02-04-2003, 11:21 AM
Lean540
Lean540's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Carbonfiber control links?
Has anyone used these?
Are they reliable?
I am afraid to try these, just worried to death the ends will pull out.
The application will be on a 27% Edge 540, this will be a high stress application (elevators)
Any thoughts?
Lean540
Lean540 is offline
Old 02-04-2003, 01:44 PM
krayzc-RCU
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have used these on various project and they hold together very well using exopy. its funny i had the same concerns when i 1st use them. you look at a plane doing a knife edge loop and realize the fin for the rudder is just glued on with a butt joint and that thing holds helps to really see the power of exopy and ca' glues.
krayzc-RCU is offline
Old 02-04-2003, 03:33 PM
gilcon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm using the Cental Hobbies ones with the titanium inserts on a 29% AW Edge. They work great. I also used black CA to hold them in - my personal pull tests showed it worked better than the JB weld that was recommended. I also slipped an aluminum ring over each end to keep them from splitting if there was a side load. I'd sure use them again and probably will on my 35% Carden Edge when I get it (kit anyway) next month. Good luck.
Hall
gilcon is offline
