to much washout?
to much washout?
Washout. How much is to much? Just finishing up a wing and it is real noticeable, so checked it and had 4 degrees of washout. Never had a wing with that much built in before.
RE: to much washout?
This is a kit cutters kit of a seaplane called Miss Grandin. Kind of like the old days, a box of wood and no instructions. I scratch build a lot but never built in that much washout, so was concerned. Thanks for the come back.
ME
I think I have too much im my Ultrasport 40 kit. Never measured it, but when I go into turns, especially right turns, the plane seems to want to drop out the turn, instaed of carve it. I read somewhere that this could be due to too much washout. True?
ORIGINAL: jzinckgra
Bill
What's too much washout?
Almost any at all on a non-tapered planform. Any at all on a symmetrical wing if you plan to fly it "symmetrically".
And you need to consider what the wing already has in it. It might have aerodynamic washout. And if it's airfoils differ from root to tip. And how much it's tapered. The question is way too general.
But if you want a soundbyte answer..... More that 2degrees is usually a waste and actually detrimental aerodynamically. A couple of degrees is almost always enough (when washout is appropriate and needed) to reduce or eliminate tip stalling. And when it's not, our having done the washing out convinces us that it is. And if we think something is helping, whether or not it does, it does.
Thanks every one for the come backs. The wing is solid planked so will have to live with what we have. I agree that not much washout is required and have never, when scratch building, built in that much. Some where down the road and after test flight will come back with my observations.
ORIGINAL: macdona
Bill
