Dave Brown spinner vs. Tru turn
My Feedback: (16)
GA
RE: Dave Brown spinner vs. Tru turn
What I have found on the two is the knurling on the back plate is a LOT better on the tru-turn.
If you use dry wall sand paper on the DB back plate, then to me, there isn't a difference.
My Feedback: (35)
KY
There's also one other thing to remember. If you order a custom spinner from TT and it's not right they will fix it at no cost. I was told by DB " If you order it you own it". Now I stay with TT. Dennis
My Feedback: (16)
GA
If you custom order a DB spinner they will fix it also if it is not right.
I just wish they would knurl the back plate more.
ORIGINAL: DadsToysBG
AZ
I have used both... The TT is the nicer of the two but to me is not nicer enough to justify the extra cost... The DB is more then adequate for me... It seems like after a few flights they get dinged up and look the same anyway...
Hi!
The problem with aluminum spinner backplates slipping on the drive washer when fastening the prop/spinner is easily fixed by either using a thin disc of 0,4mm aircraft plywood (best metode) between the back plate and the drive-washer using a sand paper disc (not too good).
My Feedback: (16)
GA
I have found that dry wall sand paper is really good.
Not the sand paper for sanding wood.
Dry wall paper looks like a screen door's screen.
Glue it on the propeller and it will not slip!
ORIGINAL: jaka
Hi!
Hi!
AL
I found a 2-1/2" DB spinner for $15.00 so I jumped on it. All I need now is the prop nut. What type of glue do you use to hold the sanding screen to the prop? Thanks.
ORIGINAL: Geistware
ORIGINAL: jaka
Hi!
Hi!
My Feedback: (16)
GA
I use epoxy.
Let it dry hard.
Make sure that the glue doesn't rise higher than the ridges on the sand paper.
Let it dry hard.
ORIGINAL: Timbotide
ORIGINAL: Geistware
ORIGINAL: jaka
Hi!
Hi!
My Feedback: (16)
GA
Are they cast aluminum?
I had a new balance spinner and it was cast.
I don't recommend cast spinners.
ORIGINAL: John Sohm
You might want to check out the Cermark spinners too. They look decent and reasonably priced too.
My Feedback: (44)
In my opinion Dave Brown spinners are a good quality, good value aluminum spinner. I have a 4" standard Vortec on my Wildhare Extra 260, it has lightened backplate and predrilled for my 3W-80xi and weighs 4.6 ounces. It's true that they don't have the polished finish that Tru-Turn does, but I will keep the extra money in my pocket and put about 45 minutes of labor into polishing my Dave Brown and make it look as good as any Tru-Turn. Here is a picture to prove it.
AL
I am glad I decided to get the DB spinner. Now I have got to buy a DB prop nut adapter. The only thing is shipping is a much as the adapter and I just placed an order with Tower Hobbies and forgot to order one.
