Futaba reciever question
CT
I have a quick question. I have a Futaba PCM reciever that is marked for Low Band. I know that the newer Futaba recievers can utilize both low and high band crystals. The model is FP-R138DP. Does anyone know if I can use a high band crystal? Thanks.
AL
RE: Futaba reciever question
I have been doing itand not had any problems.I asked the guys at Radio South and they said put a crystal in it and fly.You might lose 500 feet in 5000 but at that distance you could'nt see it anyway.............
CT
Yes, I bought it used. I range checked it and it seems to work ok. I will probably send it in as it is cheap insurance! Thanks guys!
