Reload this Page >
Radio shift question
Old 05-15-2007, 08:43 AM
oldman
Default Radio shift question
I have a couple of Fatuba recievers that I would like to use with an Airtronics transmitter. I believe these are opposite shift. Is there any easy way to convert either the reciever or transmitter shift? I know I have some Hitec recievers that have a jumper that can be reversed for shift change. What about the above? If no way, is there anyone out there who wants to exchange two Fatuba recievers for two Airtronics or Hitec on same shift as Airtronics? [ channel 42 crystals included]
Old 05-15-2007, 08:48 AM
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
Default RE: Radio shift question
Which Airtronics transmitter do you have? If you have a RD6000 or RD8000 you can use those receivers with it because the transmitter has the ability to select the modulation type. You can set it in order to use the Futaba receivers with the transmitter. If you don't one of these radios then there is no way to use the Futaba receivers with the Airtronics transmitter.
Ken
Old 05-15-2007, 11:17 AM
scratchonly
If it is a RD-6 or 8000 go to PPM/PPM Rev.
Old 05-17-2007, 08:54 AM
oldman
Thanks for the info guys but I still am having a problem. How do I do this? I cannot find any ppm/ppm functioon to reverse. I am using an RD 6000. It is an older one, prob 6-8 years. The only Modulation change it shows I can do is to change from ppm/fm to pcm/fm to ppm/fm invert. Is that what I am looking for? Can you give me any further details?
Thanks in advence.
Old 05-17-2007, 09:07 AM
RCKen
My Feedback: (9)
RCKen's Avatar
What you want is the "MOD" function. This lets you select modulation for other types of radios.
Ken
Old 05-17-2007, 11:37 AM
oldman
Thanks guys. I got it solved and it now works fine with the Fatuba rx.
Thanks again
