Air bubbles in fuel line ?
IL
RE: Air bubbles in fuel line ?
I might just give up on the Magnum Engine I looked at reviews on it and there is allot of negative remarks . It would be a good excuse to put a bigger engine on my Hanger 9 Twist PNP and put the Evo. .46 NT on the Sig Kadet .40 LT .
Not to mention picturing in my mind Britney waxed with out panties .
Bill
IL
ORIGINAL: MinnFlyer
That is the throttle stop. It does two things - It keeps the throttle from opening too far, and it holds the throttle barrel in the carb body. Don't mess with it.
#31
Well, if you're still getting big bubbles, air HAS to be getting in there somehow.
#32
I had a similar problem, with large bubbles and did all the tank stuff,only to find the air leak in the remote high end needle valve O ring.
#33
FL
from a recovering foamy fuel flyer. open the tank area and lightly wrap in soft foam rubber. isolate from the vibrations at all costs if you want to resolve your dilema. ricky
#34
AL
I used to have the same issue. I switched to Powermaster HELI fuel as it has an anti foaming additive. fixed the problem from vibration.
#35
Make sure that your fuel tank is isolated from the fuselage...I had the same problem with Sig 4Star ARF...I created some space and installed foam to dampen out vibration...I also precision balanced the prop...Huge difference.
#36
NY
Hello, I found your advice and photos regarding the air in the lines very good. I am currently strugling with a TT 60 stalling in mid flight or at climb out (ouch). I think what I am seeing is bubles as in figure one. What kind of a problem does that indicate??
#37
IL
I am not sure but I am amazed that you found this thread that is over 2 years old . I gave up on that Magnum engine 2 years ago and have never tried it on another plane ever since . Good luck .
#38
ORIGINAL: jhrdflemming
#39
ORIGINAL: Hobie
#40
MN
That screw retains the rotating throttle barrel in the carb body. I've run a bunch of Magnum engines and they are my engine of choice because of cost, performance, and durability. After all, they are a clone of the O.S. Try loosening the clamp nut that holds the carburetor into the crankcase. Remove the carb and check the condition of the O-ring. Replace it if necessary and when you reinstall the carb, hold pressure on the carb (forcing it into the crankcase) while you tighten the nut. An air leak is possible in that area. And just so you know, one high speed needle setting from the manual is not the final setting. That is just a starting point. The low speed needle is inside the throttle barrel on the side where the servo linkage attaches. A leaky back cover gasket is also a possibility. Check it.
#44
AR
mashp39, if you were asking me if I had tried the WD40, the answer is "no". It is something I have read but never needed to check out, but it is maybe the easiest fix I have ever heard of if it works. If not, no harm done. If I had a foaming problem, I would certainly try it.
#45
W.d. 40
I just reread this post and since there is not much chatter anymore at this site I thought I would just throw out a thought.What if you added the WD 40 to a new jug of fuel?The amount is open to discussion but would not this solve foaming in the first instance and and let us worry about something else?I have used Magnum engines in the past and air bubbles don't seem to be caused by any particular engine.I wonder if the original poster has read this recent discussion?
#46
I thought it was a couple drops of Armourall in the gallon. Never heard of the WD 40. it is mostly kerosene diesel fuel with a propellant. I have/had a light plane that vibrated a fair bit and the bubbles were very bad. The motor was not the problem, but the weak mounting and the plane itself. I just tossed the plane out. It did fly ok after in the air, as the bubbles went inboard. It was control line though. The OPs plane was a Something Extra, like a Twist which is a toothpick plane which could be shaking a lot. They are overengineered to be weak, I just added a doubler on mine. I like it otherwise, but the engineers should be ashamed of themselves, shot and p... on. Historical thread here. I bet things have changed, but maybe not. The motor may still be in the disappointment drawer for the wrong reason. Brittany Speers is now a senior citizen now. I guess at my age, everything looks good.
#47
Hi!
In all my 42 years of flying R/C the problem with air in the fuel line has always been a leak in the tank somewhere,never foaming. Often has the problem with air bubbles been due to a leaking rubber stopper /or the brass tubing protruding it, which most tank manufaturers use, except Tettra.
Since I started using Tettra "Bubbleless" tanks 25 years ago, first in my pylon racing planes , then i my sport planes I have never had a tank issue.
