cuts out when i accelarate
what it says on the tin. everytime i accelarate the engine it cuts out and comes to a stop otherwise it will idle forever please help me
RE: cuts out when i accelarate
ORIGINAL: daz3nt
Beyond that, some more information would be needed. What engine, what carb, airbleed or in-barrell low end screw, inverted or upright mounting - and I guess I assumed this is a glow engine.
Good luck,
Dave Olson
It could also be caused by to long a tube on the clunk. If the clunk rubs the back of the tank when the plane is held vertical, this will happen. Keep at least 1/8 inch distance from the most rearward position of the clunk and the back of the tank.
