Recovering an old plane
I am stripping the covering off an old telemaster. Some of the old covering color is sticking to the balsa. I've used my heat gun and it works some. Anyone know a quick and easy solution to this problem?
Mike
Mike
IL
Ain't no easy fix brother, it's a PITA. Some guys use acetone to get some of the residue off but you have to be careful not to soak the wood or melt any glue joints. Sand, sand, sand.
I'm just finishing a recover on a low wing racing plane. I have about 6 weeks of working evenings invested in it. It can be tedious work. Forget about acetone it evaporates too fast. I used an iron and heat gun to heat the old covering then pulled it off. Any colr residue that was left I used laquer thinner to clean up. Finishe off any stubborn spots with sandpaper.
TX
quick and easy is remove as much as possible then cover over the rest with a darker color,some of the old may show but thats quick and easy.
