Super Tigre G-61 and G-75 Engines Compatability?
I was wondering if someone on here happend to have a ST G-75, Ringed. What I need is the cylinder outside diameter and overall height, using a micrometer or other acurate instrument. I have found out that the G-61 and G-75 use the same crank case... I was hoping to install the G-75 piston and sleeve into my G-61 to act kind of as a 'hop-up/over haul'. I have already contacted ST support via email and they said no... Just curious, and would like to have real numbers in my hand so I could be the judge.
