Krylon Fusion on Elapor Foam
NE
Have any of you used Krylon Fusion paint on Multiplex Elapor foam? If so, how does it work and did you use the special Multiplex primer?
I have used this product on other plastics and the durability was fairly amazing. It seems like it should hold up well without the special primer, but I thought that it would be a good idea to ask around before I sprayed my whole plane.
