Aluminum
Reply
Old 06-16-2007, 07:52 PM
cotman
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Aluminum
Anyone know where I can get some T-6 Aluminum to make landing gear from. Thanks
cotman is offline
Old 06-17-2007, 01:11 AM
fancman
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Aluminum
Here: http://www.wicksaircraft.com/catalog...188/index.html
Or here: http://www.mcmaster.com/
ORIGINAL: cotman
fancman is offline
Old 06-18-2007, 10:08 AM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
T-6 doesn't take bending too well without cracking FYI.
vicman is offline
Old 06-18-2007, 10:35 AM
fancman
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
6063 would be better for bending but 6061 will work. Never had a problem with it myself and we're not talking severe bends for landing gear, however 6063 is much softer and not as strong.
ORIGINAL: vicman
fancman is offline
Old 06-18-2007, 02:56 PM
Campy
Campy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DO NOT BEND 6061 COLD. It will cause internal cracks (if it doesn't break in the process of bending ).
To SAFELY bend 6061 aluminum you will need the following items: Black Magic Marker, Propane torch, a couple of scrap pieces off 2x4 and a vise.
1. Mark where each bend goes with a line made with the magic marker.
2. Clamp the aluminum in the vise.
3. Heat JUST THE MAGIC MARKER LINE with the propane torch until the magic marker TURNS BROWN.
4. Using the 2 pieces of 2x4 (one on top and one underneath ) make your bend.
5. Repeat steps 3 and 4 for your other bends.
6. DO NOT drill your axle hole or trim the LG at this time. After all the bends are made, put the landing gear aside for about 5 days. The LG will reharden itself to a T4 - T5 hardness by itself in about 5 days.
7. After the LG has rehardened itself, drill your axle holes and trim.
The 2x4 above and underneath allow the bend to be made without inadvertantly bending what should remain straight. If you trim/drill before the LG has rehardened there is a very high probability of the LG bending.
Campy is offline
Old 06-18-2007, 02:59 PM
fancman
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All this is why I just buy landing gear when I need to or go with carbon fiber.
fancman is offline
