Glow vs. Gas Question
My Feedback: (84)
Hey, Everybody. I'm interested in the Hangar 9 Extra 260 27% plane. They recommend a 50cc gas engine or a Saito 2.20. The Saito is smaller in engine displacement than the 50cc gas engine. But does that mean that the amount of power that the engines put out would differ also? I believe since the Saito 2.20 is a smaller motor, that the 50cc gas engine would put out more power. Can somebody please enlighten me how this works. Thanks.
Clinton
Clinton
RE: Glow vs. Gas Question
The power will be pretty equal but; the Saito will require twice as big a fuel tank to get the same flying time per tank of fuel. Also, the Saito will be lighter and will probably require that you add nose weight to balance the plane properly.
If you can, find someone using the Saito 2.20 and see what kind of luck they have had with it.Two of our club members got them and had nothing but trouble with them.
How about a big glow 2 stroke probably give you the best preformance a moki 2.1 should make that plane gop like a he*ll but you must rmeber that glow will be more expensif in the long run (you should be able to get the fuel for the moki done at about 12$/gallon) also the glow engine is a little bit less reliable then a gas engine....
My Feedback: (84)
Well, see. I was wanting the best performance for this plane, but also, I'd like to move up to a 50cc size plane. So if I can get like a DA-50 motor for this Edge 540 120 to work with excellent performance. Because I've never used gas engines before, I'd like to try it on this Hangar 9 Edge, and then move up to an Aero Works Yak 50cc size plane or the WileHare Edge 540. Is this a plausible idea?? Thanks.
Clinton
Clinton
My Feedback: (84)
Hey, Warhawk, do you think I could make it work if I used throttle management or would it just require way too much nose weight to even do?? Thanks.
Clinton
Clinton
IN
... another factor you may want to consider is the amount of fuel you'll burn and its cost. That big Saito is thirsty and Glow fuel is way more expensive than gas, regardless of where you buy your fuel. Something I'd consider when evaluating a Glow vs. Gas purchase.
-MA
-MA
