PTS Mustang retracts
Reply
Old 06-25-2007, 02:42 AM
TGCharlie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default PTS Mustang retracts
I'm planning on putting retracts in my PTS Mustang. I have found instructions from a past post which will help a great deal along with a damaged wing.
The only thing I haven't been able to locate has been the wheel wells.
Can anyone help?
TGCharlie is offline
Old 06-25-2007, 08:45 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: PTS Mustang retracts
You don't need to buy wheel wells. Just cut away the area (About 1/2" larger than the wheel) and wet some 1/16" balsa and roll it into a circle. Then place it in the opening, Cut to size, and sand the bottom till it fits against the top of the wing. Then glue in place and sand the bottom until it is flush.
A simplier method is to fill the opening with spray foam insulation, then once it cures, cut away the excess. BUT>>> be careful! That stuff really expands a LOT and if you get too much in there you could pop the wing open. I recommend doing it in steps. Just add a little at first, let it cure over night, and add more as needed
MinnFlyer is offline
Old 06-25-2007, 09:01 AM
LuftwaffeOberst
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where is the link on that forum? I need to know what kind of retracts to get. (size related) I APed the wing halves together, so I might have to get another set of wings to put mechanical retracts in the wing. Am I right? []
Luftwaffe Oberst
Radio Aero Modelers Club
Pulaski, NY
LuftwaffeOberst is offline
Old 06-26-2007, 02:33 AM
TGCharlie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Minnflyer for the help, you've given me a couple of good ideas.
Luftwaffe, where I found the intell is as this time unavailable through its original route.
I will try and figure out how to e-mail it to you.
Old 06-28-2007, 04:28 PM
Showtime100
Showtime100's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey, I have a PTS ARF on order. Did anyone find the info on the retract install? I'd like to do it during the build as opposed to later.
Showtime100 is offline
