Want to install Flaperons
I have a Futaba 6EXAP and I want to install Flaperon on my Limbo Dancer. The instructions say to put the right wing servo in Channel 1 and the left wing servo in Channel 6 and turn the FLPR to the on positon. I have done that and the problem is when I turn the flap dial both aileron go down but when I return the dial both ailerons go past neutral to the full up positon. Can anyone help? The instructions seem quite simple and makes me feel dumb [&o]. Thanks all and have a great day.
RE: Want to install Flaperons
My 6EXAP did that too.
I've been flying with them like that. It's been fun.
At least until you forget which way to turn the dial to get the position you want.
It's tough getting old.
Thanks broke n bummin
So I have to be careful when I retract the flaps so they don't go beyond neutral? I think that will take some getting use to in the heat of battle. Wonder what the Limbo Dancer would do with both ailerons in the full up position, would it act as air brakes? I guess get about 400 ft high and then try it.
Here's a dumb question. Why do you want to use flaperons? To make more square like turns for pylon racing?
Just curious. Making your ailerons point downward, and being it as it may, most ailerons are on the wing tips, will make your airplane more likely to tip stall. By pointing your ailerons in the down postion is reducing effective wash out.
If your just playing around to see what happens well then, great! Have fun, that's what this hobby is all about. Learning somethings you just gotta do on your own!
Raf
Raf
Hi Ravill
I guess I just wanted to see how they worked. The radio is set up for it, so I thought I get the most for my money. But think I will change my mind. Don't do tip stalls. Thanks for the reply
I use flapereons quite often mainly to reduce the landing speed. I use JR radios therefore am not familiar with the set up on Futaba. however, they probably can be set up in a similar way. On my JR they can go up or down, my choice but do so only when a selected switch is thrown and I am in low motor. I must preselect the throttle stick position for them to operate. Nice because if your approach is off just go to high motor, flaps go off normal flight is resumed. I also usually mix some rudder in with ailerons when in this mode as well. It is reffered to as landing mode.
NB, CANADA
Use the little knob cover that came with your radio on the flap knob. Set it so the little arm strikes the radio case at the point where the flaps are neutral, and be merry.
Not sure if EPA might be useful to you on this... Try playing with the epa on Ch. 6. Probably would work too, unless that just sets epa for the left flaperon servo...That'd suck.
J
J
TN
Try landing with the ailerons up! This is the "air brake" configuration and gets around the loss of washout and tip stall problem by actually adding washout. It also makes the plane really stick without bouncing when you touch down.
