CG Help
CG Help
I have a G-P space walker whith a ST 75 on it.. I set the CG right no the main spar in the wing..
The prob Im having is the plane flys like it is very tell hevy. I put more white on the nose and it is still doing the same thing..
What it is doing is it will bloom up real bad.... at full, 1/2 ond 0 throtle. The plane will land hot.
for me to have levle flite the elevator will be 1/4" down.. My trim is at full down..
I do not know were the CG is to be at on this plane but most plans that I have had the cg was the best at the main spar..
if any one can help me out on this one it would be nice.. thanks
Paul
Paul
RE: CG Help
G'day Paul,
I don't believe that you have CG problem, a tail heavy plane will have a very efficient elevator, & may fly slightly tail down, when a low throttle, I believe you either don't have your elevators set at neutral with all trims neutral, or you have put it together with negitive tailplane incidence or too much positive main wing incidence, causing the balooning.
check & see,
check & see,
RE: CG Help
I did not bild this plane.. the one I got it from said that it flw grate.. all I did was put a enging on it.. but then he mite not have told me the truth about it.. I will take a look at the incidence and see what I come up with..
Thanks for the help
Paul
Thanks for the help
Paul
RE: CG Help
Well now that exsplans alot.. lol Thanks for the in for.. that is my porb.. I am no were nere that.. The spar is not that far back.. thanks
Paul
Paul
