fuel tank setup
Reply
Old 06-28-2007, 01:01 PM
kauffs894
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default fuel tank setup
I have a fuel tank set up for a 91 surpass with the air vent, main fuel inlet line and the fill line. My question is, where would I place a fuel dot, (which line)?. Or, where can I go to find set up guidelines or instructions. the instructions that come with the fuel dot shows the fuel dot being placed in line with the main fuel line but that would mean that the fuel fill line on the tank itself would be unnecessary.
HELP, Thanks
kauffs894 is offline
Old 06-28-2007, 01:37 PM
rclement
rclement's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: fuel tank setup
Welcome to RCU. [8D] I set mine up with the vent line going to the exhaust, the main fuel inlet goes to the carb and the fill line goes to a fuel dot on the cowl. The main inlet line and fill line are basically the same except that I make the main inlet line (carb inlet line) go all the way to the back of the tank but with enough clearance so that it doesn't get hung up on the end of the tank. I make the fill line a little bit shorter than that since it doesn't matter too much how long it is while filling. But keep in mind that if it's too short you won't be able to get every drop of fuel out of the tank when you want to empty it. Usually that's not a problem anyway.
rclement is offline
Old 06-29-2007, 12:33 PM
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rclement
See attached diagram.
Ken
RCKen is offline
Old 06-29-2007, 12:41 PM
Sport_Pilot
Sport_Pilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Often, I put a clunk on the muffler vent line, so it is on the bottom of the tank, and the fuel dot goes to the vent. Or it is loose in the cowl with a screw or plug. This setup will provide an even fuel mixture from the begining of the run to the end. It is called a Uni Flo setup. Works just like a bottled water cooler.
Sport_Pilot is offline
Old 06-30-2007, 11:10 AM
kauffs894
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the informatin everyone, I have been stewing over this for a few days and all of the suggestions were very helpfull. I think that the problem is that I don't have a fuel dot, but a DUBRO quick fill, that has two connections on it instead of just one . I have decided to run the intake line straight to the carb, the vent to the muffler, and the fill line to one side of the quick fill with a plug in the other side of the quick fill. This I think will give me the ability to drain the tank easily later on. if ever needed. Also I was thinking that the possibility of the valve sticking was enough of a reason not to place it in line with the intake line. Does this make sense or am I missing some important step or information with the fuel setup.
KAUFFS894
